shift light doesn' work
Old May 4, 2001 | 09:03 AM
Ken@1234's Avatar
I have a '87 Camaro with a 5 speed tranny.It has a light on the dash for best shift points.I would like to get this working. It is not the bulb.Any Ideas or a wiring diagram would be greatly appreciated.
Old May 4, 2001 | 09:15 AM
Stoopalini's Avatar
Does your ECM have an aftermarket EPROM chip? Some of the high performance chips have the shift light dissabled.
If you don't have one of these, then I would trace the wires leading to the shift light to see if they are broken.
Good luck,
Thomas
1992 RS Camaro - Red
305-TBI/5 Speed Manual- centerforge clutch/3.08 geared rear
1.6 Roller Rockers and Cam / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip
Headers - Cat Back system - Flow Master - dual chrome tips
adjustable Coni shocks & struts
Old May 23, 2001 | 03:35 PM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
<font face="Verdana, Arial" size="2">Originally posted by Ken@1234:
I have a '87 Camaro with a 5 speed tranny.It has a light on the dash for best shift points.I would like to get this working. It is not the bulb.Any Ideas or a wiring diagram would be greatly appreciated.</font>
the computer gets info for shifting from the VSS and if that was messed your speedo wouldn't work. take the gauge cluster out and check the connectors and wires. follow the wires on the back of the gaug cluster to the connector to see witch wire behind the dash leds to that light.
good luck
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
maroe624
Apr 16, 2017 08:29 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
