Where does speedo cablr connect to VSS???
Old May 13, 2001 | 01:57 AM
maksik7's Avatar
Hey people,
I'm still having probs with my speedo and odometer not working. Before I was told to check to make sure the speedo cable was connected to the VSS. Today I climbed under and looked around.
I found 1 plug connecting into something (The botom of my car is sooo caked with dirt, I had to wash it for 30 mins just to find the cable) unidentifiable. The plug had 2 wires coming out of it. 1 tan 1 pink as far as I can tell.
Is this the Speedo cable? If not where does it hook up to the VSS?
If this doesn't fix the problem what else do you suggest, also about how much will a dealer take to get this repaired?
Thanks in advance for your help. I want to get this problem repaired ASAP and start enjoying my new ride.
-Max
Old May 13, 2001 | 01:43 PM
maksik7's Avatar
Come on people, I know this is a common problem in these cars and somebody knows how to fix it. I really need some help!
Old May 13, 2001 | 08:19 PM
NitroMac's Avatar
depending on the year of car the vss should be on the front hubs, one for each wheel if you have ABS. speedometer should hook into the back of the tranny. thas all i know
you can never have too much horsepower
Old May 13, 2001 | 09:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Thirdgen's dont have ABS, so there are no sensors on the wheels.
What year car do you have? Cable or electronic speedo? Give us some more details on your car so we can help.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 14, 2001 | 12:43 PM
tpsierra's Avatar
On my 1982, the vss is on the back of the speedometer itself.
Old May 14, 2001 | 02:49 PM
maksik7's Avatar
It's an 86 Trans Am. It has the elctonic speedo. Hope that helps.
BTW the only thing connecting to my instrument panel are two jacks and definetely no Speedo cable. AHHH this stupid problem is driving me insane!
-Max
-'86 Trans Am WS6
-305 TPI with 700R4
-All stock until I fix all the problems
Old May 21, 2001 | 11:39 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
that connector ur talking about is the reverse light switch wiring
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 23, 2001 | 10:07 AM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
<font face="Verdana, Arial" size="2">Originally posted by Graeme'sFirebird:
</font>
no, the reverse light switch wires are a green/blue pair.
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old May 23, 2001 | 07:21 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The VSS is electronic & is mounted on the transmission. The wires connect to it at the tail shaft housing (aft end of transmission). The VSS connects to a VSS buffer, which is a small box (approx 3" x 2" x 1") near the ECM. It drives the ECM and the speedometer with a 4000 pulse per mile signal, and the cruise control with a 2000 pulse per mile signal.
Tim
Old May 24, 2001 | 01:06 AM
Kevin91Z's Avatar
I thought the MAF cars use a 2000 pulse signal from the VSS? Thats what Jags That Run says...
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
ZEEYAA
Apr 16, 2023 08:29 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
