Should I call the Preist to perform an Exorcism?
Old Jun 3, 2001 | 11:51 PM
pookey's Avatar
My speedometer in not working, my temp gauge and oil presseure gauges are not working. And I just found out that when I press my brake pedal when the car is off, my dash lights, parking lights come on. I already covered the car in holy water, what next?
88 White Formula 305 TBI With A New CD Stereo and Abolutly Nothing Else Done To It!
Old Jun 4, 2001 | 02:52 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
one of the 2 connectors in the back might have come lose...
or your printed circuit is going out
check all your fuses?
Old Jun 4, 2001 | 11:32 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Sounds like something may be screwed up in the dash (duh). Check for some wires, you may be getting a short to power or something running into another circuit(like shorting power to the dash lights from the brake switch)
Make it act up, and have a friend observe while you fool with stuff under the dash looking for potential problems. don't electrocute yourself, though! I've done it, sucks.
Old Jun 4, 2001 | 02:39 PM
pookey's Avatar
whats a printed circut?
Old Jun 5, 2001 | 12:05 AM
pookey's Avatar
Would having a new radio installed cause the problem?
Old Jun 5, 2001 | 02:10 AM
loc0bob's Avatar
I also have the problem where I push down my brake and the parking lights and dash lights come on.I have no idea what to do about it either.
Old Jun 5, 2001 | 09:09 PM
farbyrd's Avatar
The brake lights,caution lights,and dash lights are on the same circuit. When you press the brakes the whole system gets grounded and bingo ya get lights. Pull out your brake fuse check for burns or scoring on the fuse, if so toss it, get a new one, then with a tiny screwdriver,(touch only one set of clips at a time.*tiny*.)gently clean off any carbon on the fusebox clips. Then gently nudge the clips from the outside edges just a smidgen closer together.*not touching* just closer, they can break! Now insert the new fuse. Wave the traditional rubber chicken over the afflicted area and you should be troubled no more.
Old Jun 5, 2001 | 10:47 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Did yoy recently change any light bulbs? I had a '81 reagal that would do the same and it turned out that we put a single filliment bulb in a dubel filliment socket and it was shortin out so all the lights would come on.
Old Jun 6, 2001 | 01:22 PM
pookey's Avatar
I did change the lights recently. I'll have to check them again.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Veaceonee
Sep 29, 2016 08:15 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
