wiring up an alternater in a 92 camaro
Old Jun 3, 2001 | 09:19 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i was wondering if any one can tell me the right way to hook up an alternator in my 92 camaro
a freind of mine took out a 2.8 engine and replaced it with a 305 out of a 92 and hooked everything up for me the alternator worked fine for about a year then went out i got another one and hooked it up worked for a couple of hours then went through 4 more before it finally worked right ( i wired it up three different ways then a professional wired the fourth one up) for about another year now im going through the same problem again ( i also have a 8 hundred watt amp and four tens in the back to) the alternator is a ac delco from usa but luckily its lifetime warranty
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Jun 4, 2001 | 10:33 PM
Vader's Avatar
You might need a 1 Farad capacitor to take the peaks and save the alternator. They are about the size of a small car battery but react to current surges a lot more quickly. I lieu of that, you might want to install a second battery to take the surges, then find a 140A Delcotron from a cop car to keep up with the load. Those 70-80A peaks to the sound system alone are tough on the old alternator.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 7, 2001 | 11:32 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Get a HIGHER AMP altanator out of summit catolog, you need it, your just frying the other one, and at idle if you check your gauges I bet it reads less then 13 volts
rocn7roc
Sep 21, 2021 02:16 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
