Help with TPS and injector wires on holley tbi
Old Jun 10, 2001 | 09:07 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I had a non-IAC Holley 670tbi. So I drilled some holes and added an IAC. For clearance I had to turn the TPS around so it pointed forward. Holleys TPS has a different connect then stock so which place does my blue, white and black wire connect?
Also since the Holley injector wires are black and the factory are different colors does it matter which way I splice them together? Or should I just make sure that two of the wires going to one factory injector go to one holley injector and the other two to the opposite.
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
