gauge problems
Old Aug 4, 2002 | 09:39 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
gauge problems
My temp gauge is not working properly. Somtimes it will give the temp other times it will drop to 100. Occasionally I'll see it move around and then drop again.
Also, I noticed when my turn signals are on the tach and volt gauge bounce around slightly, whats up with that?
The tach also moves when my Brake loghts are on or if I'm using my power windows. When I use the windows the engine also sounds like the rpms dropped slightly.
Old Aug 5, 2002 | 10:20 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
check grounds on back of instrument panel and also check connection of dark green wire on your temp sending unit screwed into the engine block,
sounds like some housecleaning/hardware tightening is in need for the dash,
something i need to do on mine,., tach works one week and is all looney the next week, and temp guage pegs way out bad on engine crank and other things are funky,.
good luck
Old Aug 6, 2002 | 09:03 PM
Matto'85TA's Avatar
Thanks a lot Fast68.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
