Ignition woes
Old Oct 18, 2000 | 01:00 PM
DannysZ28's Avatar
Ignition woes
For some reason, my car is very hard to start. However, this is rectified by just moving the wires at the rear of the engine bay(next to the heater coil), and jiggling the distributor cap. Any ideas?
1985 Camaro Z28
minor mods, wires, filters, etc.
305 bored .030 over, new pistons, cam, lifters, timing kit, water pump, high-flow cat (3" out), Dynomax Afterburner muffler (2.5" out), O2 sensor, MAF sensor, 160W JVC head unit, 600W Jensen 6 channel bridgable amp, 2 10" JBL GT1000 Touring Series subs, custom box.
"You may laugh in the face of fear, but it'll be a nervous, unconvincing little laugh."
Old Jun 14, 2001 | 01:48 PM
Sena'sIROC's Avatar
Sounds to me like one of two things or both possibly causing your intermittent problem. Those wires that you are jiggling are they brown straps?? If so those are the ground straps at the back of the block. Make sure that they are secured to the firewall and then to a good spot on the block (preferably underneath the coil bracket). Nextly, I would check your HEI module ground, take off the cap and make sure that the two screws are snug on the distributor and while you're at it, make sure that your cap/rotor are clean. A fouled cap/rotor are sure weakness in the starting/idleing areas.
HTH,
Brian P
89 IROC-Z 355
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
