blows f9
Old Jun 12, 2001 | 08:03 PM
normt's Avatar
blows f9
Is 1998 camaro. blows f9 interior fuse block. says its for gauges. disconnected dash gauge asy still blows fuse.
Norman Thames
in the country
Old Jun 19, 2001 | 06:31 PM
normt's Avatar
Fuse f9, 10amp, inside fuse block blows when trying to start.
Is running light module located behind radio.
with emergencg brake did not blow
lights switched on with switch before trying to start did not blow.
find module disconnect did not blow
Old Jun 24, 2001 | 10:19 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Norm, there's a LOT of things that go through that guages fuse - the air select valve, the canister purge solenoid valve, the air diverter valve, the egr solenoid, the defogger, the convenience center audio alarm assmbly, the brake switch (auto only) the multi function lever, and of course the guages. Whew. So you could have a short in any of those things. Good luck.
"Life is pain! Anyone who says differently is selling something."
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
