Whats going on here? Car wont crank......
Old Jun 24, 2001 | 08:09 PM
TransAm383's Avatar
My car wont crank but all my accessories work just fine. I put my remote starter switch on the starter terminals but I just hear a click when I hit the switch. What does this mean? Is my solenoid shot? Does this sound like an ignition switch failure? I have a whole new starter that I could swap in but I have never done an ignition switch. Is it hard?
Old Jun 24, 2001 | 08:40 PM
Tonyrodz's Avatar
Transmission: auto
When you turn the key do the acc. dim?
What year car is it? Could it be the vats?
Although the vats won't let it click.
i had the same problem and it was my starter.
Old Jun 24, 2001 | 09:07 PM
TransAm383's Avatar
My car is an 83 Trans Am. I dont know anything about VATS. Do I even have it? Would you say it is my starter? My accesories don't really dim but my voltage gauge drops a bit on cranking and goes back up when I let off.
Old Jun 24, 2001 | 11:52 PM
Omar's Avatar
If you hooked up a remote starter switch DIRECTLY to your starter, and nothing happened, then your starter is definitely bad. Even if your VATS, ignition switch, etc, is bad, your car should of still attempted to crank.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
