Air Vent & Heat Come Out THrough The Defroster Vent By Th Windshield
Old Aug 10, 2002 | 12:51 PM
Ratstix's Avatar
WTF, worked fine yesterday. today i went to my car and turned a/c on. it comes out of the defroster vent by the windshield even if i have it on bi-level. (it also does this with te heater and vent)
what is causing this? Or where should i start looking for the problem?
Old Aug 10, 2002 | 02:33 PM
CamaroCain's Avatar
Car: 88 Camaro
Sounds like it is in default mode which happens if you loose vacuum to the control head. I would first check the vacuum lines under the hood. You should have a vacuum canister (round ball looking thing) on the drivers side under the evap canister inside the fender wheel. vacuum runs from the intake manifold through a check valve then t's off to the vacuum canister and the vacuum lines that run through the firewall by the evaporator case to the control head. make sure there are no vacuum leaks through these lines and that they are all hooked up properly.
Old Aug 11, 2002 | 01:19 AM
Ratstix's Avatar
you're right, i looked today and it was a F'd up hose that plugged into the back of the intake (next to the dist.) got new hose and it fixed the problem.
thanx alot
Old Aug 11, 2002 | 11:10 AM
CamaroCain's Avatar
Car: 88 Camaro
No problem, glad i could help.
Old Aug 12, 2002 | 11:49 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
for the two vacuum lines that run inside the cab that "power" the vents and stuff, should there be a check vavle in there? does it have to go through the vacuum ball? or can I run it straight off the intake? thanks. lil jay
Old Aug 13, 2002 | 12:05 AM
CamaroCain's Avatar
Car: 88 Camaro
well the way it is suppose to work is go from the intake through a check valve and then tee's off from the back side of the check valve. one goes to the canister(ball) and then the other to the lines going to the cab. the reason for this is so that when you take off you wont loose all vacuum to the controller which keeps your vents blowing through the correct ones on acceleration. if you hook the lines coming from the cab directly to the intake it will work, but everytime you take off it will loose vacuum and will switch to defrost, then back again when you receive manifold vacuum again.
hope this helps.
Old Aug 13, 2002 | 12:08 AM
LilJayV10's Avatar
Engine: 406 Roller
putting the check valve in would eliminate this problem? thanks
Old Aug 13, 2002 | 12:14 AM
CamaroCain's Avatar
Car: 88 Camaro
well not really. the vacuum (ball) is there so that you have a supply of vacuum. rather than just the vacuum that was left in the lines. the vacuum left in the lines wouldnt be sufficient enough to keep the a/c through the correct vents.
Old Aug 13, 2002 | 12:16 AM
LilJayV10's Avatar
Engine: 406 Roller
ohhhhhhhhh. ok that makes sense. i dont have AC, and will only use defrost and vents, does this have any bearing on anything?
Old Aug 13, 2002 | 12:23 PM
CamaroCain's Avatar
Car: 88 Camaro
ok, maybe i made you think that it only matters with a/c, but in order to get your blower motor to blow through anything but the defrost mode you must have the vacuum hooked up properly.
Old Aug 13, 2002 | 12:57 PM
LilJayV10's Avatar
Engine: 406 Roller
cool man, i appreciate your help. :hail:
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
Todd84Z
Sep 4, 2015 08:02 AM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
