Speedometere reading high
Old Aug 12, 2002 | 01:56 PM
Andrew88iroc's Avatar
I recently purchased an 88 iroc-z 5.7 TPI. Amongst modifications made by previous owner are 3:27 gears. I notice that the speedo is reading about 20mph higher than actual speed. Is this a result of the modified gears? and if so what can be done - or is it just a busted speedo? appreciate your help
Old Aug 12, 2002 | 03:09 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Speedometers can be calibrated, but you need the right equipment - ie a rolling road.
Old Aug 12, 2002 | 03:17 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
the tires may be a different size from stock. although 20 mph seems a little high a little too much for just different size tires. i would think the difference would have to be a couple of inches for it to be that different.
your speedo may just be busted. good luck either way.
Old Aug 13, 2002 | 11:54 AM
Re: Speedometere reading high
Thanks your replies - I did find some info on checking and adjusting the speedometer at
http://www.speedometershop.com/ratio.html#ADAPT
GTAman
Mar 15, 2019 11:40 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bryanwood74
Sep 24, 2015 09:50 PM
GTAman
Sep 21, 2015 09:57 AM
Linson
Aug 21, 2015 02:12 PM
