vats
Old Jul 8, 2001 | 12:16 PM
steveclk's Avatar
vats
bypassed vats module with a resistor car had no problem for a few weeks,then the problem came back,took car to several mechanics to check my work they said i did a good job bypassing vats module ,one of them said the only option i have left is to buy new vats.called the dealer new one sells for $400(live in canada parts are expensive)is there anything else i can try or do i spend money on a new one .please help tia
Old Jul 8, 2001 | 02:06 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
And what happens if you spend $400 for a new module and it doesn't fix it?
What I am saying is, how do you know its the module? What is (or isn't) the car doing? What clues have lead you to a VATS module failure? The reason I am asking, is I have yet to see a "failed" module, and 80% of the cars I work on are equipped w/ VATS/PassKey.
If it is indeed a module problem, you can totally eliminate the VATS completly w/ a custom PROM. Send me an email for more details btripp@sethirdgen.org
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
