car battery ALWAYS DYING!!!!!!!!!!!!!!!!!!!!agrrrrrrrr!!!!!!!
Old Jul 3, 2001 | 02:10 AM
burnoutrpm's Avatar
ok i need help BIG TIME! everytime i shut off my car something kills the battery..and fast try like 15min-to a 1hr at the most to completely kill the battery ! it just started this out of the blue!? just for no damn reason it started this crap!i had everything like the alt and starter tested!FINE!i tried disconnecting every single fuse one at a time and left it overnight and the batt still went dead !!!!!the batt is also new and have had it tested and load tedted many times its fine?! i have to disconnect the positive lead of the batt everry time i shut off the car!!!this is of course very annoying!!!!i have checked the fusioble li9nks aT THE batt alt and starter and still they are fine and it continuse to die?wtf? why? i put a new groud strap on it today and it slowed the drain from 15 min to a full hour maybe 2hrs if im lucky! i even disconected the horn altogether.i am at a point where i want to shoot my car ........HELP!!
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1405edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!.with lots of NOS
Old Jul 3, 2001 | 06:48 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Check the hatch motor.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 3, 2001 | 09:26 AM
Stuart Moss's Avatar
disregard
[This message has been edited by Stuart Moss (edited July 03, 2001).]
Old Jul 3, 2001 | 09:34 AM
disregard (used "reply with quote" vice "edit" button)
Old Jul 3, 2001 | 09:37 AM
What is the voltage with the car running at idle?
What is it with the engine at ~1500 or more RPM?
What is it after the battery has been charged (after having started the car), say after about 10 minutes?
I know you said the alternator/battery were tested, but maybe the output of the alternator is not getting to the battery properly for some reason. I am thinking this because you said that the battery (with the car off) would last longer another ground cable was added. That, to me would indicate that the alternator would be able to charge the battery better (due to a poor ground soemwhere?), and thus have more capacity, or have a longer discharge time.
But having a better ground with the engine off (alternator not charging) could only increase the current drain, or shorten the time before it goes bad, but you said adding another ground made the battery last longer. Having a poorer ground (with the engine off) would make the battery last longer due to the increased resistance and thus less current drain.
Old Jul 3, 2001 | 09:38 AM
disregard
Old Jul 3, 2001 | 09:39 AM
disregard
Old Jul 3, 2001 | 09:44 AM
disregard
(dumb error - pls don't ask)
Old Jul 3, 2001 | 07:24 PM
burnoutrpm's Avatar
come on guys please help i tried the rear hatch motor idea and the car still does the same thing!!!! .......dang help please!!!!...im begging literally!!
89 firebird formula
comp cams xe262 cam
#1405edlebrock 600
Old Jul 3, 2001 | 10:14 PM
Mr. Burnout from outer space,
So does that mean that you have not measured the current draw of the batter while the car is off?
I described several methods in the above post.
If you do that, I think you'll be well on the way to solving your problem.
But then again what does this bumbling fool (me) know.
Old Jul 3, 2001 | 10:17 PM
disregard
Old Jul 7, 2001 | 04:57 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
same thing happened to me.
check the relay at the hatch (pulldown motor)
or the other relays with engine off.
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel -americanracing rims (ar26) rear 15x8 255/60
front 15x7 235/60
www.members.aol.com/tramphorst/pontiacpics
Old Jul 7, 2001 | 06:54 PM
allbee1's Avatar
i have the same problem i even put a hi out put alternator 130 amps its charging good but in a few day batterie will be dead let me know when you get it fix so i can do the same email me allbee1@aol.com
84zzzzzzzzzzzzzzzzzzzzz28
with a 350 .030 over eagle piston and rods r.v cam team g intake 750 holley card msd dist. with 6al box edelbrock headers 5 speed
Old Jul 11, 2001 | 08:50 PM
chooch-88formula's Avatar
Try taking the hot lead off of the altinator, and see if the car dies then.
Or better yet... hook up your volt meter to the battery and the start unhooking power wire from different locations (alt, starter, fuses) and check the voltage everytime you unhook something.... if your batt dies that quick there should be a huge drain on the batt, and when you find it, the batt voltage should go up a little. ( 11.5 to 12.5 or something like that)
88 Formula WS6 TBI 350
The other hobby
http://home.rochester.rr.com/hoscar/indexn.html
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
