wierd problem
Old Jul 6, 2001 | 06:22 PM
Deimos's Avatar
wierd problem
Last night when i was heading towards the mall. I had only my fog lights on,(88 maro V6) and then all of the sudden my gauge lights start to flicker and my car seem like it wanted to die. whats up with that? I have my fogs running off the fuse block instead of the battery itself. Is that the resaon for it? or is it something else? Also when i dimm the gauge lights and then i try to make them brighter they stay off for a second and then come on. Please help.
Old Jul 7, 2001 | 01:37 AM
edin's Avatar
hmm... i dont think u want fog lights running off yer fuse panel, i would run it off yer battery if i were you.
91 camaro rs w/t-tops, 5sp, open element K&N 14X3, K&N filter top, dual flows, mallory ign, AR 89-92 camaro big block hood w/functional hood scoop and cowl induction, new dark red glittery paint, z-28 grill, z-28 rims, funky circular corvette tail light fiberglass piece and taillights (came with car, ugh), 4th gen front seats, bottom potion of my backseat (not bolted in, just laying there), pioneer 1.5din cd player, blaupunkt 6x9s and 4x6s, some other various mods as well.
future mods include either a 383 or a big block w/blower, 12 bolt rear, posi, 3.73 gears, trac bars, new rims and tires, even newer 4th gen seats (all of them), all windows tinted, 6sp, 2 12" subs and a good amp (already have a nice custom camaro box), paint the funky circular fiberglass piece!
previous car was an '82 camaro berlinetta w/sunroof and w/355, 3sp, shift kit, msd ignition, edlebrock performer carb/manifold, dual flows, 14x3 k&n open element, headers, new dark midnight blue paint, 14" grand prix rims and tires, 3.73 gears, posi rear
Old Jul 11, 2001 | 08:43 AM
georgiaboy27's Avatar
fog lamps + fuse panel=bad,boo boo,fire, not good,wrong thing to do...
Old Jul 11, 2001 | 04:24 PM
Deimos's Avatar
yeah that was for the mean time though. I currently dont have the fogs hooked up anymore but last night I had the same problem but with just my headlights. It doesnt have to be night time either. What the hell is it??? please help and thanx in advance
Old Jul 11, 2001 | 06:11 PM
82 cross fire's Avatar
You mightt try one of two things for this. There are two cirit breakers in the fuse box if one is going out they will do some realy wird things. As for the problem with the dash lights that sounds like you need to replace the lightswitch. Be warned that that is a real pain.
Old Jul 11, 2001 | 06:17 PM
Deimos's Avatar
what do the circuit breakers look like and how much am i looking at to replace them? are they a pain in the *** to replace as well. this **** sucks man im scared of my car dying when it does that ****. so if i replace the circuuit breakers it might work? thanx for the help.
Old Jul 13, 2001 | 05:33 PM
1fastirocLS1's Avatar
what's going on? i work at a chevy dealer and i also have the same problem. check with your local dealer, have them pull bullentins from si2000(computer progam) on your car you should find a relay that you will need to replace to correct this problem. good luck
<font face="Verdana, Arial" size="2">Originally posted by Deimos:
what do the circuit breakers look like and how much am i looking at to replace them? are they a pain in the *** to replace as well. this **** sucks man im scared of my car dying when it does that ****. so if i replace the circuuit breakers it might work? thanx for the help.</font>
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
