white wire on coil........
Old Jul 16, 2001 | 11:58 PM
87tpi420's Avatar
i should have asked about both at once.....does anyone know where the white wire from the coil runs? can i just connect it to a ground or what. would like to know where the factory ran it
on an 87 z-28 tpi
Old Jul 17, 2001 | 03:58 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There are two white wires going to one side of the primary winding of the coil & two pink wires going to the other side of the primary winding of the coil. The large pink & small white wires that go to the coil from the under hood harness are for ignition power and the tachometer, respectively. The small pink and small white wires that go from the coil to the ignition module in the distributor are to supply ignition power to the distributor module, and the output of the ignition module to the coil, respectively.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Jul 17, 2001 | 11:51 PM
87tpi420's Avatar
maybe i should have been more specific. i have ripped out the stock harness and put in a dfi harness, now i have found out through one reply so far that the pink wire (i have a pigtail on coil with gray connector) goes to the pink wire coming out of the drivers side firewall which is ignition power. the smaller white wire i have no clue where it goes. i have the end that goes to the distributor allready plugged in. so what i need to know is... on the pigtail i have, there is a white and pink wire (pink goes to ignition power) where do i run the white one? is it tach signal pickup or is it just a ground or what , i am confused please help!
gary
Vintageracer
Jan 10, 2020 05:33 PM
GTAman
Mar 15, 2019 11:40 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Gumby
Members Camaros
Aug 21, 2015 12:50 PM
stalkier
Aug 13, 2015 12:59 PM
