Where is the VATS fuse
Old Aug 17, 2002 | 06:47 PM
JodiGirl's Avatar
I have a factory service manual, but it doesn't show where the VATS fuse is. Any help with this would be appreciated.
It is for a 89 Formula. I have narrowed my starting problem down to the VATS system.
Thanks for any help you can give.
Old Aug 17, 2002 | 11:34 PM
92RSB4C's Avatar
It's on the fuse block, under the dash on the drivers side, but pulling the fuse wont help. If you're having starting problems, check out my web site. It'll help you out. BTW (By the way), welcome to the boards.
Old Aug 18, 2002 | 03:03 AM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
actually... on most models its on the accessory block, which holds a couple of relays and the hazard flasher. the fuse block is closer to the door, while the accessory block is closer to the heater vent (right foot).
at least, that's where i found it on my 89 Iroc and my 89 TransAm.
Joker
Old Aug 18, 2002 | 06:33 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It's in the fuse panel driver side. Welcome to the boards.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
