just got power mirror parts from another car ...how do I wire them?
Old Jul 16, 2001 | 12:59 PM
jm91rs's Avatar
I switched interiors of my car with another vert. That other vert had power mirrors so I switched that also, switched the mirror itself and took some wiring. I have all of the wires that go into the car on both sides, but the wires between them were left in the other car. How do I go about wiring up my new mirrors? I would guess that someone else has done this and might know where to connect each wire.
Jeremy
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon...non red interior with 4th gen charcoal/grey seats
Old Jul 16, 2001 | 01:54 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may find the wiring diagrams for the mirrors at:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Jul 16, 2001 | 06:48 PM
jm91rs's Avatar
that is a bit confusing, but I will try to follow it.
Jeremy
Old Jul 17, 2001 | 04:46 PM
jm91rs's Avatar
that really isn't much help. You see, the passenger side has a white wire, a blue, a yellow, and a green wire. The left side has a white wire, a green wire, black wire (ground), an orange wire (power) and two blue and two yellow. I know to wire orange to the accessory fuse, the black to a ground, and I would guess, wire the other colors to the matching colors on the other side of the car, but how do I match up the two blue and two yellow? that will leave a left over of a blue and a yellow.
Jeremy
Old Jul 17, 2001 | 04:48 PM
jm91rs's Avatar
I also wander if the drivers side should work when I connect the power and the ground, it doesn't work when I tried it, but it seems like it should.
Jeremy
Old Jul 17, 2001 | 10:45 PM
orange rocket's Avatar
I did mine today! Thanks Tim. Heres the deal... Orange off switch goes to ignition. Black goes to ground. Split the blue and yellow to both mirrors. Then look at switch and when dr side is selected the white and green off that go to dr side and same deal for passenger side.
Old Jul 22, 2001 | 12:18 AM
jm91rs's Avatar
well, maybe my extra ble and yellow came off the mirror then, I was pretty sure that those wires all came into the car. I already have one side of the orange and green wired to drivers side.
Jeremy
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
