How to bypass the VATS?
Old Jul 16, 2001 | 11:06 PM
hawaiiguy's Avatar
My car hasn't started in about a month. I checked everything and it all funnels down to the pass key module. I hooked up a ground to the starter relay where the pass key hooks up and it started for about 10 seconds then cut off. I figure the computer picked up on it and shut the injectors off. How would I fix this problem. Can i just go around the P_key module and how.
92' RS 305 TBI
Old Jul 17, 2001 | 04:51 AM
Omar's Avatar
Are you positive that it's a VATS problem? By you grounding the starter enable relay, it should of just cranked and cranked, and not started for 10 seconds.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
[This message has been edited by Omar (edited July 17, 2001).]
Old Jul 17, 2001 | 07:35 PM
hawaiiguy's Avatar
Now all it does is crank and crank. I checked everything, and it all goes to the pass key!
Old Jul 29, 2001 | 12:50 AM
colincamaro's Avatar
take a multimeter and read the resistance in your key, then find the 2 wire connector under your column[I beleive the wires are yellow and brown] Buy a resistor at radio shack and connect the two wires that go to the module,not the column with the resistor. I think theres an article in the tech articles section on this.
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Racerx974
Sep 19, 2015 10:16 AM
