Internal Turn Signal/Wiper Switch?
Old Aug 21, 2002 | 03:21 PM
HurtHorseZ28's Avatar
My left turn signal does not shut off automatically and my wipers only work when they are switched to the washer pump mode. The lever is loose when I try to select low and high.
Anyone ever replace the internal switch in there? How much does the part cost and how hard is it to do? I know you have to pull the wheel. Thanks!
Old Aug 21, 2002 | 09:19 PM
2vmodular's Avatar
Re: Internal Turn Signal/Wiper Switch?
turn signal not automatically cancelling when the steering wheel is turned is a common problem with older general motors products and is usually caused by a broken return spring. replacement springs are avaliable for around $2.00 in the "help" or "motormite" section of many parts stores.
turn signal switch is seperate from the windshield wiper/washer switch. your problem is more often caused by cracks in the multifunction arm rather than a bad switch assembly.
multifunction arm is easy to replace if your vehicle doesn't have cruise control. but if you've got cruise and want it to remain operational, you've got to disassemble the column to fish some new wires.
Old Aug 22, 2002 | 12:10 PM
Well the problem is probably both. The left signal doesn't shut off automatically and the wipers only work when in the washer mode. I don't have cruise and already tried swapping out the lever, but it is not that. Definatly an internal problem.
Old Aug 22, 2002 | 01:37 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
If I remember correctly the switch was like 80 bucks from GM, and you pretty much have to take the steering column apart to get it in and out
PATRIOTIC1911
Sep 1, 2015 07:26 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
ZsTransAm
Aug 11, 2015 07:30 PM
djmarch
Aug 9, 2015 05:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
