Knock Problem
Old Jul 25, 2001 | 08:31 PM
chooch-88formula's Avatar
Knock Problem
I keep throwing the (43) knock code. I'm trying to figure out if it's the sensor or the ESCM. I thought I should be able to measure 12V coming out of the ESCM while not driving? or do I have to be driving down the road at ~40MPH?
Any Ideas?
thanks Rick
88 Formula WS6 TBI 350
The other hobby
http://home.rochester.rr.com/hoscar/indexn.html
Old Jul 26, 2001 | 12:04 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Code 43 - Electronic Spark Control
Check the voltage at the ECM connector terminal B7 (or the black wire on the ESC); it should be over 6volts unless the system is seeing detonation. Check for a loose connection. Replace the ESC sensor or module*
* Haynes disclaims this really fixing the problem but hey,, you gave it a shot anyways lol
The mind is like a parachute, it only works when its open
Old Jul 29, 2001 | 08:12 PM
Big Dad's Avatar
I read 9vdc from the ECM but 0 out of the ESCM.
Sounds like the ESCM? huh?
thanks
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
