no cranking issue--ignition disabled??
Old Jul 30, 2001 | 01:39 PM
Rayzer999's Avatar
Car: 91 Z28 LS Swapped
Engine: 5.3 Turbo LS
Transmission: T56 Mag
I recently took my bottom dash area apart to trace a interior ACC wire problem that kept blowing fuses. Now that I have found the wire that has been shorting I repluged in all my wire harnesses in the stering columb and found that I cannot start the car. All my dash lights apear and my gagues flux when I accel the ignition switch..but it acts as tho I do not have the newtral switch engaged. I have checked all fuses and they are fine...the starter advances when it is arked at the terminals....but I still cannot find my problem. My alarm has been disconnected and reconnceted and I have reset the PASS system by disconnecting the battery several times....any ideas!??
Old Jul 30, 2001 | 06:34 PM
Rayzer999's Avatar
Issue solved...thanks to any that helped
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
