signal light kapput
Old Aug 23, 2002 | 04:37 PM
muffler's Avatar
signal light kapput
i have a 88 sc here is the problem
i have no signal light whatsover. i replaced the fuse then the signal relay. what else is the problem.i should also mention that i have nothing in the dash ether. when i filck to go right nothing happens no dash light no outside lights
i heard that on those models if u have a blown bulb it will not work could that be the problem.
pse help i need this car by tomorrow. its getting a new body job.
tks
muffler
Old Aug 23, 2002 | 10:30 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
if it was just a bulb then the light inside would come on and stay on (not blink) you also didnt mention what was going on in the back. just a guess but it sounds like you have a poor connection either in the bulb socket or elsewhere in the wire
Old Aug 23, 2002 | 10:59 PM
muffler's Avatar
everything in the back works as its suppose to. no problem there
i checked and there was 2 bulbs blown
would that be the problem
Old Aug 26, 2002 | 02:20 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
if it works now than that was the problem. I've never had two go out on me at the same time.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
dibella989
Sep 1, 2015 04:12 PM
Omega
Aug 10, 2015 12:46 PM
