Starter enable relay, Tim burgess and GMTECH please step in.
Old Aug 3, 2001 | 09:59 PM
mat89RS's Avatar
I'm having problem finding that da*n relay, I have a 1989 RS 305 TBI and I need to know where it is . I have looked all over the driver under dash, driver kick panel, I just don't know what is looks like
89 Camaro RS Stock as a women with white panties
LT1 IS COMMING SOON.
Old Aug 3, 2001 | 10:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its a flat relay and is usually behind the drivers side kick panel. I think it has a fat TAN/WHT wire and a fat YLW wire going to it. Try also looking under the carpet in that area.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 3, 2001 | 10:18 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
It is behind the drivers kick panel, but may be hiding behind what looks like a square rubber cover...
KAM
Old Aug 4, 2001 | 12:41 AM
mat89RS's Avatar
Ok, I found it , it was well hidden into the kick panel insulation, it was dipped in a type of rubery compound . thanks alot guys
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
Formula_88AE
Sep 3, 2015 01:47 PM
