Fans For 89 Gta
Old Aug 24, 2002 | 08:58 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
Fans For 89 Gta
WHERE IS THE FUSE FOR THE FANS? (MAIN POWER)
Old Aug 25, 2002 | 01:22 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Probley an inline fuse by the starter OR it's in the fuse panel under the dash.
Old Aug 25, 2002 | 01:53 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
I CHECKED BOTH PLACES, I WANT TO KNOW EXACT LOCATION.
FUSES GOOD AND IN-LINE FUSES GOOD
Old Aug 25, 2002 | 02:03 PM
well have you tryed seeing if the fan has power by manually grounding the relay by probing the wires using a small pin and probing the fan wire or connector. Also check to see if the relay is getting power. Doesn't sound like a fuse problem then.
Old Aug 26, 2002 | 05:25 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
FANS AND RELAYS WORK. SUPPLIED MY OWN 12V AND WORKS
FINE. i WANT TO KNOW WHERE THERE FUSE IS SO ITS STOCK.
Old Aug 26, 2002 | 06:18 PM
Should be on the fuse block, look for a 30 AMP fuse
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
