Tach Adjustment
Old Aug 2, 2001 | 11:54 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Tach Adjustment
Is there a way to fine tune a stock tach kind of like the fine tuner thinge on a aftermarket one
Old Aug 3, 2001 | 12:08 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Good question, I would like to know that two because on my 1992 RS V6 the tech reads a 1000 but in reality it is 790 RPM
Old Aug 3, 2001 | 12:07 PM
un4givin89's Avatar
I'd like to know this too, cuase I just installed my home made white face gauges and I think my tach is off a few. I could have swore when I was crusing down 64 at 80MPH that in overdrive the tach read 30 or 35 now it reads 25. But when I'm idel or going normal it reads where it always did. Maybe I'm just mistaken, would like to know though
[This message has been edited by un4givin89 (edited August 03, 2001).]
Old Aug 3, 2001 | 06:02 PM
tacoboy's Avatar
heh, it might actually be correct now, as mine reads 23 at 79 with a 3.08 rear...so depending on your rear it might be accurate now
Old Aug 5, 2001 | 12:41 AM
Anybody, hey can we move this one back up on top!!!!
Old Aug 5, 2001 | 08:55 PM
Iroc n roll's Avatar
My Tach is also off by about 2000RPMs... Someone has to know whats up.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Aug 5, 2001 | 10:58 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Hey un4givin89 when you did the white face gauges did you have to take off the pointer? If you did I was wondering if there is a slot on the tach shaft that the pointer must slide on or do you just line it up and stick it on.
Old Aug 5, 2001 | 11:10 PM
un4givin89's Avatar
Old Aug 6, 2001 | 08:54 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
That is good I guess I will havr to adjust it the hard way.
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
