Headlight Relay in '88 GTA
Old Aug 30, 2002 | 08:46 AM
J Kylez's Avatar
Where is the Headlight relay in a '88 GTA? Also where are the fusable links for the motors located?
Thanks,
J
Old Aug 30, 2002 | 04:22 PM
2vmodular's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=126586
Old Sep 2, 2002 | 09:23 PM
J Kylez's Avatar
I found the headlamp module. I pull the inout connector and neither side goes up.
I check the voltage at the connector and found 12 V between both motor leads and chassis ground on the good side. No voltage on either wire on the non-working side. Does this point to the headlamp module or a fusable link??
Thanks again!
J
Gunsbee
Sep 7, 2015 07:10 PM
Glowsock
Sep 6, 2015 06:40 AM
machinist21
Sep 5, 2015 03:03 PM
luvofjah
Sep 3, 2015 07:08 PM
