#1 cylinder
Old Sep 9, 2001 | 07:42 PM
89Irocz23's Avatar
#1 cylinder
ok where the the # 1 wire on the distrubutor at. The wire from #1 cylinder to distrubuter. Where is it at.
Old Sep 9, 2001 | 08:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Old Sep 9, 2001 | 08:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The #1 cylinder is the front cyl on the drivers side of the engine.
http://www.deadbird.org/tech/spark.gif
That's a firing order diagram.
The #1 position can really be set anywhere on a distributor depending on how it's dropped in.
I don't know if any of the helps or not.
The mind is like a parachute, it only works when its open
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
