1LE L98 oil pressure??
Old Sep 8, 2001 | 09:18 AM
Mubie's Avatar
Real quick, my oil pressure guage reads right around 60psi 95% of the time even under normal driving conditions...I had Midas change my oil last time because I was in a rush and didn't have time. I'm getting ready to go Mobil 1 5w-30 synthetic...should I expect a drop in pressure? 60 seems kinda high if I'm not stompin on my car.
Old Sep 8, 2001 | 01:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its possible your oil pressure sending unit is bad and not reading correctly, or the gauge is off.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 15, 2001 | 04:45 PM
Mubie's Avatar
I actually took a closer look around the valve covers and intake manifold. On the drivers side there is some oil collecting...look to be coming from either aroudn the PCV valve or valve cover on the drivers side. SO, would it the oil ports possibly be clogged?? The car has 24K miles on it and has had 3K changes. I was given all those by the previous owner.??
Old Sep 15, 2001 | 10:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Since I've rebuilt my motor,, my oil pressure is +60psi, reading the same using my old sensor or new, there's nothing really wrong with having high oil pressure,, it's better actually.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 15, 2001).]
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
