altenador problems help please?
Old Sep 12, 2001 | 11:42 PM
BryanJ's Avatar
I have no idea what is wrong? I have gone throught about 6 altenadors all of them charge fine from anywhere between 5 min to 3 days then the voltage drops low! I have checked all my wiring and found no mistake.
Please help,
Bryan
Old Sep 14, 2001 | 01:11 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are you using rebuilt alternators or brand new ones?
There has to be something wrong with your wiring, as alternators dont fail that often for no reason.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 14, 2001 | 10:00 AM
BryanJ's Avatar
These are all remanufactured altenadors, I have checked all of the wiring and I can't find any flaw. The voltage regulator had a chip in the side of it about a 1/4" long so I but a new one on and I'm gonna give that a try.
thanks,
Bryan
Old Sep 19, 2001 | 08:45 PM
Belker's Avatar
The rebuilt alts are probably your problem. Rebuilt alt quality is a Huge gamble and the quality usually stinks. I hope you got a warrenty and get'em replaced for free when they go out. If no warrenty - then go buy a new unit, not a remanufactured one. If still under warrenty - then keep taking it back and getting another one - eventually you'll get one that will last a couple years. This has been my experience.
Old Sep 20, 2001 | 12:17 PM
mtccl's Avatar
Have you checked, charged and/or replaced your battery each time? If you replace an alternator with a dead battery still in the car the alternator will attempt to charge the battery and fry the alternator. Rebuilds are suspect, but not at the rate you are experiencing.
1987 Trans Am, 305 TPI, K&N, Cherry Bomb Muffler
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
