Help a Dead IROC
Old Sep 21, 2001 | 05:50 PM
87IROC_IT's Avatar
Help a Dead IROC
I have a 87 305 HEI with external coil car. I changed plug wires to the new accel 8 mm wires and i custom lengthened them. Dones this before quite a few times. No problems but i changed the cap a nd button and the damn thing wont start. It misses when it actually does. i brought the motor up to tdc #1 lined up timing mark and put the #1 wire on the terminal the button was at which happened to be just about in the middle of the front of the distributor. WONT RUN Wont even start now. One thing i noticed is on the passanger side under the exhuast manifolds i see a black wire with like a slide in connector on it. It goes back past those annoying little tubes that hook into the exhuast manifold. Is this why?? Did i accidently knock it off during wire replacement. I have the fireing order right too i know this for sure. I start with the terminal i think is #1 and go COUNTERCLOCKWISE exactly what is written on the intake correct? Any help would greatly be appreciated. Thanks
Doug
Old Sep 21, 2001 | 08:32 PM
89Irocz23's Avatar
I have that little wire too I have no idea what its for but its not hooked to anything and mine still runs good.
Old Sep 21, 2001 | 11:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Clockwise.
The mind is like a parachute, it only works when its open
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
lt1z350
Aug 28, 2015 05:57 AM
spaigo
Aug 21, 2015 07:46 PM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
