Dead Short on new motor
Old Sep 25, 2001 | 10:23 PM
87ColdAirIroc-Z's Avatar
I just put my engine back in my car and i have a dead short somewhere. If i put a volt meter on the + battery cable (not connected to battery) and the + terminal on the battery i get 12.5v (the negative terminal is connected). I also have continuity between the + battery cable (unconnected) and the - battery terminal(connected). The alternator and starter are okay and are not shorted out. All ground cables are disconnected from the engine block. Where could this short be coming from? If i have to test each wire how can i do this?
thanks
jake
87 Iroc-Z 350 TPI
Dynomax exhaust
modified MAF & filter box
modified ARAP chip
3-10" JL subs
Eclipse components
Old Sep 26, 2001 | 07:39 AM
hotpowerandperf's Avatar
The short you are speaking of could be something as simple as the light on the hood or the juice required for keep alive memory of the computer. To find the short pull the fuses one at a time and check again. When the short goes away you have isolated the circuit. I would also measure the actual current draw of the short. If it is small there is a good chance it is one of the above and therefore normal.
John
Heart of Texas Power and Performance
theshackle
Mar 5, 2017 06:37 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Bradsaundry
Aug 12, 2015 12:34 AM
