Horn not working the way it should
Old Sep 25, 2001 | 05:47 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I've decided to replace the standard horn on my Camaro with a two-tone setup from a 1985 Cadillac Fleetwood. This particular vehicle had two separate horns; one for each tone. I bolted them into the engine compartment and hooked them up. When I press the horn button, they chirp for about half of a second... I cannot make a long blast. When touched to the terminal of the battery, or another 12V source, they work fine together. Is there too much of a load (being that I now have two horns) for the stock horn relay? If so, what kind should I replace it with?
1986 Camaro IROC-Z
Code 23 Paint ("IROC Blue")
305 TPI
B&M Megashifter
Grant GT Steering Wheel
New A/C Motor!
View my website, a work-in-progress
Old Sep 26, 2001 | 10:28 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Anyone?
Old Sep 26, 2001 | 03:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Are you sure the contact in the steering wheel is good ? The horn 'button' is the ground for the relay.
As for load, both my cars have dual horns, the wire is merely spliced from the one connector to a 2nd for the 2nd horn. No 2nd relay or thicker wire so I'd assume horns don't draw all that much power.
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited September 26, 2001).]
Old Sep 26, 2001 | 03:55 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I'm going to go out now and verify that the horn button is making a proper ground... although I believe that the button is good. I just replaced my steering wheel about two months ago.
Old Sep 26, 2001 | 05:55 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Turned out to be a bad connection in the relay socket. Thanks, problem solved.
Old Sep 26, 2001 | 11:37 PM
deadbird's Avatar
Engine: TPI 305/ v6
Welcome I gues,, even though I guessed wrong to actually help lol. Glad you got it fixed tho,, I really know how much it sux not having a working horn. grrr
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
