wiring mega shifter need info pls.
Old Sep 15, 2002 | 03:26 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
My back up lights stay on. The insturtion show the blue and green wires for back up on the upper switch. The blue wire remans hot. any ideas or info would be great thanks. Tim
Old Sep 16, 2002 | 05:49 AM
BILZ88350's Avatar
This was my same problem also. Did you buy the the extra switch from radio shack as the instructions called for? If so; then you have to adjust the limit switch until it goes out. There is some play to allow for this and if this fails; slightly slightly bend the "finger" contact on the swich until the lights go out. There is a very fine line of adjustment on the 2 switches when stacked together.I noticed that if not adjusted properly; the button on the switch stays on as the finger keeps it there even though you have selected another gear and the finger is off the little "boss" on the shifter plate.
1992 Trans Am
May 10, 2023 07:19 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
Dialed_In
Aug 20, 2015 01:45 PM
