Electric speedometer
Will an electric speedometer still function
properly with the computor disconnected?
This is a 91 FireBIRD 3.1v6 that will be receiving a healthy carbed v8 and pro-built
700r.If it won't, will a mechanical speedo
& cluster from a 85TA 305TPI auto swap into
the 91?
the 91?
Car: 91 Red Sled
It should. Just don't put any v6 tranny up against a v8 unless you REALLY like working on your car
The vss doesn't go just to the ecm, it goes to the speedo two and they are independant of each other as long as you didn't cut any wires.
, Jon (350 TBI!)
91 Red My website
.The vss doesn't go just to the ecm, it goes to the speedo two and they are independant of each other as long as you didn't cut any wires.
, Jon (350 TBI!)
91 Red My website
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sorry JPrevost, you're incorrect. The computer has everything to do with an electronic speedometer. The signal goes from the trans to the computer. Then the computer sends it to the speedometer. On a cable-driven speedo, the trans turns the speedo with the cable, then there is a sensor mounted on the back of the speedo that sends the signal to the computer. An electronic speedo wont work without the computer or some other way to control it. A cable speedo doesnt require the ECM.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I thought the VSS signal went to the VSS buffer then split the output seperatly to the ECM & speedo ?
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
On some setups, like TBI ECMs, '84 - '86 (digital dash) Berlinettas, and pre '91 digital dash FB / TA's, the VSS buffer is external to the ECM, either near the ECM, or behind the driver's side kick panel, in a small plastic yellow or black box, with two plugs attached to it. With '91 & '92 V8 TPI & V6 MPI, the VSS buffer is located inside the ECM.
Brian, you could use your electronic speedo & VSS if you get a VSS buffer module from GM (for a '91 305 TBI) or from a junk yard.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Tim
TMZIrocZ350
Oct 7, 2015 12:09 PM
