headlights motors not working right
Old Oct 9, 2001 | 02:21 PM
mm4tt's Avatar
1982 Pontiac Firebird S/E 2.8L 6
right now i have the cables to the headlight motors unplugged, but if i plug them in while the lights are in the down position, they will stay down, and when i turn them on they stay down. however, when i reel them up manually leaving them on, and then turn them off with the switch, they go down, how can i fix it so that it will go up too? this has really annoyed me, spent a long time trying to fix it...
-Matt
Old Oct 9, 2001 | 10:52 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Try locating the isolation relay, It is located, at lease on the harness I had was near the pass. side headlight. or check the other two relays that controll the motors them selves. same locations but adding the driver side as well. One of them is taking a **** on ya.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!! GREAT!!
Flowmaster exhaust
LT1 Injectors
Old Oct 11, 2001 | 06:18 AM
scauffiel's Avatar
...and if that doesn't do it for ya, check my website for another couple of fixes.
Steve
Steve's Trans Am Temple
Old Oct 11, 2001 | 11:20 AM
mm4tt's Avatar
im not sure what the relays look like, can you explan to me? ... also steve i cant see anything on that site of yours..
Old Oct 11, 2001 | 08:20 PM
mm4tt's Avatar
! man now it wont go up or down, i checked all fuses all are good..!?!
Old Oct 11, 2001 | 09:38 PM
mtccl's Avatar
This drove me nuts for the first 2 weeks I owned my car. Replaced the relay, opened the motors and nothing worked. Turned out to be the modulator. Either located under the lower console or in may case mounted to the firewall next to the windshield wiper motor. Take the thing out and press on it some. Just slides out of the bracket. Wiggle the wiring too. My old one would work intermittently before I got the new one off E-bay for $8.00.
1987 Trans Am, 305 TPI, K&N, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Old Oct 11, 2001 | 09:41 PM
mtccl's Avatar
modulator picture link
www.angelfire.com/ma4/transam/modulator.jpg
<img src="www.angelfire.com/ma4/transam/modulator.jpg:>
Old Oct 11, 2001 | 10:11 PM
mm4tt's Avatar
that pic isnt showing up..
Old Oct 12, 2001 | 06:25 PM
AaronIROCZ's Avatar
Sorry to say but you don't have the module. That was used in the 87 up firebirds with the 2 wire motors. You have the 3 wire motors, correct?? Which use the relays. The relays are square and have 2 connectors that go into each, they fit together like a puzzel. Trust me a buddy of mine has a 86 T/A and his was doing the same thing. He replaced the relay or relays and it all works good now. I believe one of the connectors on the relays are gray??
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
MINI RAM SOON!!!!!
had engine fire
Flowmaster exhaust
LT1 Injectors
[This message has been edited by AaronIROCZ (edited October 12, 2001).]
Old Oct 12, 2001 | 09:34 PM
mm4tt's Avatar
yeah exactly, i know what yor talking about, .. il check it out, thanx...
Old Oct 14, 2001 | 06:17 PM
scauffiel's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mm4tt:
also steve i cant see anything on that site of yours..</font>
Try here: http://www.transamtemple.com/modific...ght_repair.htm
S.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
