smoked a wiring loom....
Old Sep 17, 2002 | 07:18 PM
MouseCamaro305's Avatar
l dropped a wiring loom on the headers and l burned the wire to the fan which l connected to the blower motor for fan control. after the wire had been smoked the car shut off, now it doesnt have power to certain things. l think it mightve, or another wire mightve shorted the ignition switch. heres a list of things that work and things that don't. can anyone help me out?
things that work
horn, lights, dash lights, headlights, and the dome light
things that don't work
radio, guages, turn signals, brake lights, reverse lights, hazards ignition chime. anyone know my problem? BTW l checked all fuses, theyre all golden.... can't figure it out.
anyone that can help would be great, thanks a lot.
Old Sep 17, 2002 | 08:59 PM
87Formula391S/C's Avatar
Car: 87 Formula
Engine: L98-350
Transmission: 700-R4
Axle/Gears: 3:08 Posi (Disk)
was it a posative or a ground wire you burned off sounds like a pos+. i'd look for the ground wire fore that circuit
Old Sep 17, 2002 | 09:15 PM
yeah its a positive, but its still intact, if it wouldve burnt and not caused a short, the fan would be the only thing not working.... its burnt, but still conducts electricity.
Old Sep 18, 2002 | 09:23 AM
theres still voltage to the starter, and after the starter, but more than half of the fuses under the fuse panel have no voltage to them, the rest have 12.3 volts. l checked the wires for voltage right before the wires go through the fire wall and don't know what could've possibly blown inside the dash. Is there a fusible link inside the dash that could've blown? l can't figure it out.
any additional help would be greatly appreciated.
chazman
Aug 28, 2018 03:25 PM
IROC315
Oct 27, 2015 09:57 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
chazman
Aug 22, 2015 02:01 PM
Fronzizzle
Aug 17, 2015 02:52 PM
