Help Horn Dome light an cd playe wont work ahhhhhhh i need music
Old Sep 19, 2002 | 04:09 PM
Crazy2.8V6Man's Avatar
OK i have checked my fuse and yes it was blowen so i replaced it and it blew right away and again and again i have put so meny damn fuse's in that thing and have no idea what the problem is i cant find a shorted wire eather so i have no ****in cue plz Help any one.
Old Sep 19, 2002 | 09:27 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
there has got to be a short somewhere. you need to get a wiring diagram and check all the wiring on that circuit.i'm pretty sure this wire is orange and it goes all over the place
Old Sep 20, 2002 | 12:21 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Make sure some loose change hasn't fallen down in you cig lighter. Also pull the radio and see if that stops it, there is a slim chance +12v constant is somehow grounding against the radio chassis causing the problem.
As jw said, something on the ACC circuit is causing a short making it blow fuses.
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Links above are for 85 & 86 camaro sc. All interior wiring is basically the same throughout the years.
82-83 firebird diagrams are here
http://www.deadbird.org/tech/8200.htm
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
