Wiring Location
Old Oct 24, 2001 | 08:37 PM
Chad's Avatar
Wiring Location
I'm wiring my fog lights, and I cant find a place on the drivers side of the firewall to feed the wire into the dash. Any help would be great! Thanks!
Old Oct 24, 2001 | 10:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have cruise (and maybe even if you don't) there is a grommet just under the carpet behind the brake pedal. If there isn't one,, it still save to drill a hole there. Remember to put a grommet in the hole to keep the wire from getting cut on the metal.
*edit- if you stick to right under the carpet line about centered w/the brake pedal,, it will come out under the brake booster pretty tight to the frame rail.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited October 24, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
JFry
Aug 19, 2015 01:25 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
