chip in key with no comp??
Old Sep 21, 2002 | 04:41 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i ripped out my computer and switched to carb and i am wondering if i still need that little chip in my key or no? thanks
Old Sep 22, 2002 | 02:25 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
you shouldnt need the resistor key. It was used for the VATS system and since you took the computer out you wont need it.
Old Sep 23, 2002 | 07:21 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You will probably need to jump the starter relay that feeds the solenoid. That relay is activated by the VATS module. It is usually located driver side under kick panel. You can either remove the relay and jump the contact pins, or simply wire it to energize with any key on voltage.
Old Sep 23, 2002 | 06:06 PM
Car: 89 Formula
Engine: Carbed 5.7
yea i alreayd jumped the starter a while ago but today i went and had a key made but without the chip in it and it won;t even turn when u pout the key in the ignition. they are both exactly the same to.
Old Sep 28, 2002 | 03:00 PM
BillD91RS's Avatar
Do you mean that the ignition will not turn or that the car will not turn over. I don't believe that the resistor in the key would keep the key from turning. If that is the case I would take the key back and have them cut you a new one.
Bill
Old Sep 28, 2002 | 06:08 PM
Car: 89 Formula
Engine: Carbed 5.7
i mean the key won;t turn in the ignition. they look to be exactly the same to me
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
Gunsbee
Sep 7, 2015 07:10 PM
