Code 33 Help Losing My Mind Need Help!!!!!!!
Old Sep 21, 2002 | 08:01 PM
jrspeed38's Avatar
HELLO EVERYONE I HAVE A 1985 TRANS AM WITH A 305 TPI AND I AM GETTING A CODE 33 I HAVE RESET THE ECM MANY OF TIMES.I ALSO CHANGED THE MAF AND THE ECM.BUT THE 33 CODE IS STILL THERE I AM GOING CRAZY.I WAS READING SOMETHING ABOUT A BURN OFF RELAY ON THE BOARDS BUT I AM NOT SURE WHERE IT IS OR WHAT IT LOOKS LIKE.IF ANYONE KNOWS OR HAS ANY IDEAS PICTURES LOCATION THAT WOULD HELP ALOT. PLEASE HELP I DONT KNOW WHAT ELSE TO DO I WANT TO LIGHT A MATCH AND CALL IT QUITS ANY INFO WOULD BE GREAT.
THANKS KYLE
JRSPEED38
Old Sep 27, 2002 | 08:10 AM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
I think the burnoff relay is on the firewall next to the master cylinder. I went through that with an 88 TPI 305 and it turned out to be a bad mass airflow sensor that I had already replaced. I got another one at the junkyard for 15.00 when I paid a 150.00 at the auto parts store that would give my money back for it. Anyway I replaced every sensor on the car before I came back to that mass airflow sensor. Take a screwdrive and lightly tap the MAF Sensor and see if the car changes idle or sets the code. That could be what it is.
Old Sep 29, 2002 | 07:00 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most times it is caused by dirty relay contacts on either the MAF burnoff or power relays. Replace them both, they are on the driver side firewall next to each other. The MAF itself unless it is mishandled physically is a very reliable unit and is often misdiagnosed when all the problem is are intermittent relay contacts.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
tmellott89
Oct 14, 2015 02:06 PM
Lmancha96
Sep 25, 2015 08:11 PM
Deemax
Sep 12, 2015 06:53 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
