Please help w/ shift light!
Old Oct 20, 2001 | 09:53 PM
chevyboy07 91's Avatar
I have a Proform shift light I'm trying to install and have a couple questions. The instructions say RED=12V ignition switch, Black=good engine ground, Green=Tach terminal(for GM, HEI, MSD) or to coil negative (for standard ignition).
Where is the best/easiest place for my RED wire and where the heck does the green wire actually go? I didn't know we had a "tach terminal" on our cars. Can someone please fill me in.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Oct 24, 2001 | 03:32 PM
mtccl's Avatar
Need to know whether you have an internal cap coil HEI ignition or an external coil ignition or a regular old coil and a traditional ignition.
87 TA, 305 TPI, Custom CAI, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Old Nov 3, 2001 | 06:00 PM
I do not have an "in cap" coil system. My coil is separate. it is all factory for 92 ANYBODY!?!?!?...thanks
Old Dec 26, 2002 | 07:20 PM
CrashedMatrix's Avatar
the green wire on you light goes to the white wire on your coil.
Old Jan 7, 2003 | 01:31 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Run the red wire to the ACC plug on the fuse block...And the green should go to the plug on the distributor...My distributor has it labeled faintly...Or the negative side of the coil
Old Jan 7, 2003 | 06:56 PM
MdFormula350's Avatar
use something called a fuse tap which will slip over one of the contacts of the acess. fuse and there is your 12 volt ignition source.
Old Jan 8, 2003 | 11:43 AM
Jza's Avatar
Jza
Make sure it's the fused side of the fuse and not the feed side.
You can find out which is which by touching each terminal with a test light and the fuse removed (key on). Whichever one doesn't light is the side you tap.
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
