where can i put a wire through my fire wall from inside my 92 z28
Old Nov 4, 2001 | 06:00 PM
FastAndFurious's Avatar
im wiring up some illuminating gas and brake pedals and was wandering can i send the wire through the fire wall and were is the best spot to put the switch
Old Nov 4, 2001 | 07:22 PM
Vader's Avatar
Why don't you just get the power from the fuse panel? An ignition circuit would be good, so that the pedals would go dark with the key off. Or connect them to the tail light circuit, so that they are on whenever the lights are on.
All of that wiring is already under the dash.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 4, 2001 | 08:40 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
Word of wisdom..why make something light up that your feet are going to be covering. Just do what I did..use neon highlighting cables and blacklights...rocks when you are rollin through town..:P
But yes, he was right about those circuits. It all depends on when you want them on.
305IrocZ28- Al
1990 Iroc-Z
305 TPI
0-60 in 6.8 (timed)
2.73 Posi (3.42 or 3.73 to come)
Flowmaster exhaust
T-tops
Red w/ black racing stripes
Pioneer headunit, stock speakers, Rockford 10'' punch woofers
Ricers beware...I eat you three meals a day
And the Camaro said to the Civic "Now, I know what you're thinking...in all of that mess, did he have 8 cylinders, or only 6? You just gotta ask yourself one question...do you feel lucky? Well do ya....punk???
Old Nov 5, 2001 | 03:29 AM
Kandied91z's Avatar
i agree that you should tap into the circuits already in the car less mess under the hood.
but if you must their are at least two main holes located on the firewall on either side of the car; both having rubber grommet type covers that can be easily removed so that you can pass a wire through.
1992rs/ss
Jan 31, 2025 05:10 PM
92camaroJoe
Jul 29, 2023 07:57 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
