Bad MAP sensor?
Old Nov 3, 2001 | 03:55 PM
ImportEater's Avatar
Bad MAP sensor?
It's a 3.4L from a '94 Camaro. It's using the SFI and DIS from the '94 Camaro. It starts then runs fairly rough for 2-3 seconds at most. I know that I have ignition voltage and fuel during start and run until it dies. Is this a symptom of a bad MAP sensor, or does someone have a better idea?
Old Nov 3, 2001 | 07:41 PM
I don't know what the problem was, but I did get it to start up, and stay running -- so the MAP sensor wasn't the cause of that.
Old Nov 8, 2001 | 01:10 AM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Well I have a 92Z28 and I just replaced
my map sensor.It ran but ran badlyIt was
also dumping way too much fuel in the motor
I may be wrong but see if any trouble codes
come up first.
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
