Can Someone Please Tell Me Were to Wire My Gauges
Old Nov 7, 2001 | 09:13 PM
killer305's Avatar
i ordered 4 autometer gauges and was wondering if anyone could tell me were i could wire them on a 90 camaro, details would be helpful. thanks
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 7, 2001 | 10:16 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
What kind are they? Electrical/mechanical? Oil,fuel press,water temp? Mechanical gauges usually only have a ground and hot wire that goes to your parking lamp wire,which would be brown in our cars. As far as the sending units,if you e-mail me with the kind of gauges you are getting,I'll e-mail you details.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Nov 7, 2001 | 10:22 PM
killer305's Avatar
i got fuel press mechanical, oil pressure, trans temp, and air/fuel what i really need to know is where i wire it to a 12v sorce, and ignition and anthing else it need to be wired to
Old Nov 8, 2001 | 07:17 PM
chevyboy07 91's Avatar
the place to go w/ your 12V ignition source is on the fuse block. If you duck down there and read towards the back of the box you will see the letters "IGN" and 2 arrows pointing to the connector. Just crimp on the proper connector to the wire..any conncetor kit has the proper connectors you will need (I think its a spade connector...*not sure*) and shove it in there. Now you are good to go. If you have multiple wires that need to go to the "IGN" just use a "wire tap" connector onto the first wire u stuck in there and you are all set.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
