I'd like to add a heated o2 sensor... Where's a good place to tap for accessory pwr?
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I have longtubes now, and the o2 bung is in the mufflex ypipe. It has been recommended for me to ad a 91 Zr1 corvette o2 sensor. Where did you tap into the harness to run the heater? Does anyone know which wire is signal, ground, and power on the sensor? Thank You!
