newbie question...jet chip
Old Nov 8, 2001 | 08:38 PM
G92 IROC's Avatar
What are the pefromance gains from using a Jet chip, stage 1? stage 2? Any cons?
If i plan on spraying next year, will i still want one of these?
Yep, its a newbie question, and i hope i posted it in the right place
...ack...
thanks in advance,
mike
[edit]- btw, the mods i'm getting very soon= ram air, porting plenum, SLP runners, porting intake, cam, ignition, and spray as i mentioned before...
[This message has been edited by G92 IROC (edited November 08, 2001).]
Old Nov 8, 2001 | 08:45 PM
G92 IROC's Avatar
Didn't include sig. before, now u know what i have
1989 G92 Iroc 305 5spd 3.45 posi
mods: airfoil, MAF screens, flowmaster 80's, K&N's, TES headers, Catco hi flow cats (dual of course).
Other:
Tints, Eclipse CD8051 HU, Nakamichi pa504 (50x4 watts), Polk 4x6's, Polk 6x9's, Xtant 1001x amp (1000 watts), 2 xtant X-series 12 inch subs= people know i'm comin' a block away
Soon= ram air, ported intake, cam, ignition
Old Nov 10, 2001 | 10:21 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
In my experience I have had nothing but problems with JET chips. Once you start modifying your engine different from stock setup you will start having a lot of annoying problems. If you want a good chip have it custom programmed for your car setup.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported Plenum
-- Blue LED Bakelite Dash & Climate Control
"Just some 17 Year old spending every dollar I make on my car."
Old Nov 10, 2001 | 02:46 PM
JPrevost's Avatar
Car: 91 Red Sled
You think YOU have problems after mods...try doubling the horsepower and using speed density setup! Now that's when you had either go carb or put down $300 for custom eprom burning (eprom or equipment to do it yourself).
MAF has it's downsides but they adjust better to bolt ons than any of the other systems.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
