ALTERNATOR SWITCH
Old Nov 13, 2001 | 06:42 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
ALTERNATOR SWITCH
OK I've been reading High Tech again,has anyone installed one of these switches to disconnect the alternator instead of removing belt(not actually disconnecting it but disengaging it)how do I do this ? ?
89 FORMULA 350,WS6 SUSPENSION,HOTCHKIS STB,KONI REDS,WONDERBAR,SLP REAR CONTROL ARMS/PANHARD,POLY BUSHINGS,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,FLOWMASTER EXHAUAST,SLP 1 3/4 HEADERS,NO CATS,58 MM BBK,MINIRAM INTAKE,COLD AIR,ALL FREE MODS
Old Nov 13, 2001 | 08:39 PM
Omar's Avatar
Just out of curiousity, but why would you want to do this?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Nov 14, 2001 | 02:32 PM
JPrevost's Avatar
Car: 91 Red Sled
Not a good idea if you have EFI. If you've got a carb, fine, it doesn't care. EFI needs the extra voltage. There is a stock program built into your ecm that does funny things when the voltage drops below a point.
There is a tech article on the GNtechboard that shows you how to raise or lower your voltage by "tricking" the alternator into thinking the voltage is higher or lower that reality. This will vary your voltage
Hotrodboba400
Dec 10, 2019 07:07 PM
Randomtask2
Sep 10, 2015 08:37 AM
64goatman
Sep 9, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
