About to start blue LED dash project
Old Oct 2, 2001 | 06:37 AM
crucial's Avatar
I'm about to start my new LED project. It's going to be modifying my 91's dash for LEDs. I plan on buying about 100 high brightness LEDs (about 3000mcd) and use them to light up the numbers on the dash blue. I plan on using two LEDs per number for each digit. Since the needles have a transparent core I plan on putting blue LEDs behind the needle core so the whole needle lights up blue. The blue and red should make for a nice combination and it should match my Sony deck beautifully. I will post pics withing the next few days.
1991 Z28
Old Oct 2, 2001 | 10:41 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
tight
i want to add this tight panasonic head unit...the one that is silver, but glows blue at night....but that'd totally throw the mellow red/orange glow scheme off, so i'll probably end up with a sony too.
lemme see how it looks when ya get it done.
Old Oct 3, 2001 | 09:52 AM
FiReBReTHa's Avatar
nu uh., dont think so, not until you get us pics of your last project.....
even a pic will give me an idea...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 3, 2001 | 10:48 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
what ohm resister are you planning on putting in the circuit for the led? Or are you planning on making a seperate power supply.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported Plenum
-- Blue LED Bakelite Dash & Climate Control
"Just some 17 Year old spending every dollar I make on my car."
Old Oct 4, 2001 | 12:54 PM
crucial's Avatar
For my last project I'd have to get a video made.
And no I dont plan on using any resistors. I will put 7 LEDs in series with each other or however many it takes to get the manufacturer's mA rating. I changed my deck to an AIWA CDC-MP32 which is also blue and red and plays MP3s to boot!
1991 Z28
357 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4.
Old Oct 4, 2001 | 01:47 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
so you are not going to modify the factory bulb holders. You are just going to run a wire in series to all the LED’s. I want o change the dash on my bro’s 92 to Blue LED's. but how are you planning on mounting then?
Lightly Moded:
Old Oct 4, 2001 | 05:18 PM
crucial's Avatar
Oh hell no! The LEDs wont be even half as bright as the bulbs. I plan on mounting the LEDs right on the back of the gauges with lots of hot glue!
Old Oct 4, 2001 | 06:50 PM
FiReBReTHa's Avatar
really.??
hmf, i picked up some LED's awhile ago, and man they GLOW., better than bulbs, more Aimed, but bright,
im suprised... oh well...... *cougH*PicsNVideo*cough*
sorry, coming down with LEDTaillight*itis,
LoL, ya, but i think its cause theyre diff bulbs
91 FireBird 305 V-8
Old Oct 11, 2001 | 02:42 PM
dbarkley's Avatar
Car: 1985 Trans Am
Transmission: 4spd auto
I agree, high intensity LEDs are pretty bright. And as far as how many you hook in series, it's not the current but rather the voltage that determines how many you're going to put together. You're right tho with 7 bulbs, assuming they drop 2 volts each and 14VDC with the engine running. The LED's will actually consume less ampres, depending on how many yer gonna glue on! :P
Old Oct 18, 2001 | 09:49 AM
FiReBReTHa's Avatar
hey crucl, sorry to bug you, was curious about the pics... i know you were working on a video, but im curious on how you setup the leds, and how you wired them... i want to start planning my proj for winter...
thnx, and hope the dash proj is going well...
91 FireBird 305 V-8
Old Oct 23, 2001 | 03:54 AM
crucial's Avatar
I took em off the car before I got a chance to make the video. I can show you the LED clusters I built if you want
I'm redoing the whole thing professionally. I'm going be using SCSI cable headers to get the LEDs to stay up straight and get then perfectly aligned and also use 6 LEDs in series then use a voltage regulator to supply the 6 leds a constant voltage. That way I can get rid of the annoying flickering at idle.
1991 Z28 6.0 TPI
360 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Old Nov 8, 2001 | 10:02 AM
FiReBReTHa's Avatar
actually thatd be great, because i was curious on where you put them cause i would imagine where you place em greatly affects that....
you think its possible to do sequential blinkers?
im new to electronics, im learning as much as possible... but whats your thoughts? my car will never be stock again,
91 FireBird 305 V-8
Old Nov 8, 2001 | 10:24 AM
crucial's Avatar
You can do the sequencer part of the lights pretty easy, but dont you think it would look pretty stupid with red, yellow and white lights back there ?
I was about to do the dash but I'm gonna wait till the funds allow me to do so. 60 blue LEDs costs quite a bit these days !
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, aluminum driveshaft, WC 5-speed etc
Old Nov 9, 2001 | 12:13 AM
FiReBReTHa's Avatar
i thought ahead, i have TA lights now,
chheck sig, ,page one, theres a picture....
tell me watcha think, if i can get ahold of some $$, and some new TA lights, id be willing to get you some financial assistence with your project,
91 FireBird 305 V-8
Old Nov 11, 2001 | 10:15 AM
crucial's Avatar
Aaaaaah, well that might look a lil better huh. lol
I have this new idea where I'm gonna be using computer cable IDE style connectors to put the LEDs in, in an effort to keep them all nice and straight so the light pattern is uniform. I think I'm gonna do that pretty soon here. I'll let you know how it goes and I'll take some pics. I think I'll also make a small voltage regulating circuit so it keeps the voltage at a preset level at idle so it doesnt flicker like it used to.
1991 Z28 5.7 TPI
Old Nov 13, 2001 | 06:57 PM
citgofan99's Avatar
Radio Shack is the place to get anything you need to position your LED's. Try using a piece called a breadboard (it is a circuit bord with patterned holes for placement of electronic components) these can usually be cut to size. I've used them in the past for other projects without any problems. Please post some pics of your finished product. I am very interested in the results.
Old Nov 15, 2001 | 02:04 PM
crucial's Avatar
A breadboard would be a little harder to work with but it might be easier to incorporate the voltage regulator on it and I could do pretty much any design I want. I was thinking of two small circles for each "rectangle" on the light, since on IROC lights the red part is divided in three.
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Street Lethal
Aug 14, 2015 08:25 PM
