electric hatch switch doesn't work and i dont have the key
Old Nov 22, 2001 | 02:17 PM
FastAndFurious's Avatar
this car im fixing has no key for the rear hatch or doors just the ignition. but the other problem is that the switch for the hatch dosnt work either. fuzes are fine to. it would be great if you could help.
Old Nov 22, 2001 | 02:57 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
FYI:
If the car is running or ingnition is on, the ebrake must be on in order for the switch to be operational.
First check the switch to make sure it isn't bad. I don't think that there is a way to open it with out the key then. Well.. unless you smash the lock and the center section of the lights, and i don't think you want to do that.
You will have to get a key cut for the door locks. I think that you can get them from GM.
Can you pick locks?
Old Nov 22, 2001 | 05:20 PM
ill try it
Old Nov 22, 2001 | 06:38 PM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Omega:
FYI:
</font>
Dont forget that that is only true for a manual tranny. For an auto, it just needs to be in park or neutral.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Nov 23, 2001 | 04:22 AM
Omega's Avatar
Engine: LS1 / LS3
Omar, this is true with my 89 A4 bird. I thought it was strange, but thats how the car is.
Old Nov 24, 2001 | 12:31 AM
Chris Luongo's Avatar
My friend's '88 GTA, with automatic, still requires that the parking brake be applied to release the trunk.
Pop out the switch and have a look at it. If it just has two thick wires... apply 12 volts to one wire, and then the other... trunk should pop open if it still works.
If it has small wires, there's a separate relay... remove the hush panel from under the passenger dash and it's up in there somewhere. But you'll probably need a multimeter to check if the relay is bad.
Also, you don't need the trunk key to open the hatch in an F-body. At the junkyard, I was able to crawl into the hatch, use a quarter to unfasten the panels back there, and I could flex it aside enough to reach in there. At least on the older cars, you can release the hatch with your finger once you get in there.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
tnrednneck
Aug 13, 2015 08:57 AM
