vss sensor
Old Nov 14, 2001 | 11:03 PM
89/90 rs/iroc-z's Avatar
vss sensor
i put a 90 tpi in my 89 rs. i replaced the dash wires with the 90 one and the spedo was electric so used the old cluster and re wired everything. now would the senser give a differant signal to the ecm than the 90 digital sensor
Old Nov 15, 2001 | 02:40 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
In the '89 cable driven speedo system, the optically driven (from the cable) VSS buffer at the rear of the cluster sends a VSS signal to the ECM & the cruise control, which I believe is a 2000 pulse per mile signal. With the '90 ECM setup, the VSS buffer is built into the ECM & requires an VSS mounted in the transmission. In the '90 system, the ECM drives the speedo in the cluster with a 4000 pulse pe mile signal, and the cruise with a 2000 pulse per mile signal, so you will probably have to replace the cable driven speedo in your '89 cluster with an electronic speedo - either after market, or (this would be more difficult) try to transplant the electronic driven movement from a '90 speedo in your '89 cluster & redo the numbering. Another option would be to try & use a '90 - '92 cluster in your '89, but the form factors are different.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Nov 15, 2001 | 09:22 PM
well i will see what i can find at the junkyard this weekend.
thanks for the advice
Old Nov 16, 2001 | 09:23 PM
will it cause the car to run rong if i dont hook it up
Old Nov 17, 2001 | 05:32 AM
Jza's Avatar
Jza
Your TC won't lock up (if you have an auto) and your purge solonoid won't work properly resulting in a fuel smell on shutoff. Car'll run fine, but altogether losing about 3mpg and increasing average heat levels in the tranny. Not that big a deal when you're just trying to work out the bugs from your swap, eh?
Old Nov 17, 2001 | 05:49 AM
yeah the 89 has a t5 which is nice. i have been driving it and never smelled a gas smell but when i turn the car off the pump runs for a sec and then turns off. is that ok.
Old Nov 24, 2001 | 02:28 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by 89/90 rs/iroc-z:
yeah the 89 has a t5 which is nice. i have been driving it and never smelled a gas smell but when i turn the car off the pump runs for a sec and then turns off. is that ok.</font>
yea the pump will run for 2 or 3 seconds after you shut the car off.
Old Nov 24, 2001 | 09:33 PM
is there any way to put together all the parts i need to get the vss up and running without having to do any major mods. the tranny i have is a t5 but the engine and harness came out of an auto.
$750 L98
Feb 1, 2025 02:25 PM
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
